Can anyone help me with describing the operation of the following ? | on ElectriciansForums
Discuss Can anyone help me with describing the operation of the following ? in the UK Electrical Forum area at ElectriciansForums.net
Slidey
The principle of operation of a moving coil instrument
The principle of operation of an electrodynamic wattmeter
Explain the principle of operation of a kWhr meter
If anyone can direct me to information that can help me out or answer these questions they would be greatly appreciated.
Ok if we use a resistor of say 1.5 ohm but high wattage say 100amp the resistor would vertually be a piece if metal strip.....This is commonly call a shunt. if we place this shunt in series of our supply and powered circuit, we get a very slight volt drop. if we measure the voltage across this shunt we will get a reading in mv proportional to the current being drawn. So now we have an amp meter, rescaled from mv to amps. If you now know the current, and you measure the voltage you can calculate the wattage. modern methods use inductive coils but maybe this will give you an idea of now how to calculate
Shunt ammeters are normally only used for DC.
Reply to Can anyone help me with describing the operation of the following ? in the UK Electrical Forum area at ElectriciansForums.net
R
Can anyone help me identify these bathroom taps please? Hi Can anyone identify the make and model of these taps please? We have one dripping...
Richt5a
R
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
