Can anyone recommend a decent sds cordless and combi drill set? | on ElectriciansForums
Discuss Can anyone recommend a decent sds cordless and combi drill set? in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Evening all
im in the process of looking for a decent sds cordless drill and combi drill?
ive used dewalt for past few years, combi has been ok. Used it with the nano batteries and they have out lasted both drills.
think is time I change them
any one recommend a decent set?
I was quite happy with the combi set. First one lasted about a year. Second one is still working, and using the nano batteries which are still goin strong.
The sds cordless 18 v only lasted about 2 years and a bit disappointed. Mayb used it too much.
Looking at bosch 18v set or the milwaukeeset.
For me the 36v is a bit chunky and when I'm drilling bigger holes I tend to use 240 v drill. I need something light and easy to use in tight spaces. Also something that has interchangeable batteries so I have access to more batteries
18v sds by dewalt, makita or milwauke then.
Im a makita man myself personally
Bosch 36v are practically unbreakable and feel like they will go on forever
I have this combi and it's a great little tool. It's not as heavy duty as the HD18 as Shanky says, but I find the only limitation it has is a weak hammer. So coupled with the SDS it would make a great kit.
I use it as my main drill and it copes with everything I use it for, with the added bonus of being small so you can use it between joists. I even strapped its handle on and used it with a 52mm diamond core bit with no complaints last week.
How long is it? Ive been eying up for a smaller drill mine is too long.
First time I saw the 458 I thought it was low-mid range because of size its tiny.
A mate at work uses the dewalt 14.4 and its a bloody good drill can stand up to 18v drills easily
Reply to Can anyone recommend a decent sds cordless and combi drill set? in the UK Electrical Forum area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
