Can FP 200 be burried in the wall without RCD??? | Page 2 | on ElectriciansForums
Discuss Can FP 200 be burried in the wall without RCD??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I had a similar issue with interconnecting alarms and concluded with the use of radio linked alarms. I was initially concerned about compliance, however the manufacturers verified it's compliance with Part B 1.21.
The only issue was location, however positions were acceptable in close proximity to lighting points, and the rigidity of the fp200 enabled a 50mm clearance from point to point.
Mr NIC man and Mr Building Inspector were both happy.
Reply to Can FP 200 be burried in the wall without RCD??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
