G
goldie
Can i add new circuits to a system (rcd protected ofcourse) with under sized main protective bonding, without having to upgrade to 10mm2?
E.G tn-c-s earthing system with 6mm2 protective bonds but should be 10mm2 as neutral is less than 35mm2, This could be a code 4 on a pir or code 3 on a ecr which would not fail the inspection, but do i still have to make sure that the bonding is brought up to date?
