Electrician Jobs Can i connect 2 sockets to a fused socket and this inturn to a other fused socket
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
There is a double socket on the wall where the main feed comes in and this is then connected to a none switch fused socket. Iv'e been told i can add a other fused switched socket and connect both together then run 2 additional sockets off the fused switch one?
Welcome to the forum mate.
What do you mean by a "none switched fused socket"? Do you mean one of these?
Does the circuit you are adding to have RCD protection?
Does the way you intend to add the extra sockets need the wires to have RCD protection?
We need more info mate.
Note @Spoon comments. The non-switched 'fused socket' is confusing the question unless it looks like the item pictured.
I'm looking again at the original question.
why would you want to add another fused connection after the first?
so:
ring socket <---xFCUx---xSKTx---xSKTx
if those sockets take more than the first 13A fuse they will stop (fuse blows).
so:
ring socket <---xFCUx---xSKTx---xSKTx--xFCUx---xSKTx
makes no sense - the same would happen. The first FCU protects the connected sockets.
That said. You need to look at what loads you are expecting to connect and where they are positioned on the ring. By design a leg on the ring (the cable between sockets) the Iz shouldn't go above 20A. If you are adding these sockets to either end of the ring, those closest to the CU - you could well do that. You need to calculate the leg length impedances for the final ring and calculate the expected current going both ways (parallel circuit). Someone qualified and with the correct test equipment can calculate these for you to make sure this would comply.
I think I scared the OP off, by asking questions..
He posted at 4:56 am. Maybe posted before work or after night shift? So either he's just due home or just getting up?? I didn't even realise that time existed on a Sunday.
Adam888,
Moley,
