can i get 2 gang switch 1 fused and 1 normal ? | on ElectriciansForums
Discuss can i get 2 gang switch 1 fused and 1 normal ? in the Electrical Tools and Products area at ElectriciansForums.net
J
Jak1708
Hi all
is it possible to get a 2 gang switch with one being a fused spur switch and the other being normal ? or do they have to be seperate ? i cant find one but wondered if anyone else knew of one ?
thanks
Jack
Reply to can i get 2 gang switch 1 fused and 1 normal ? in the Electrical Tools and Products area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
