I
ihave4kw
I have a question, basically can i heat my water using my immersion and the power from my 4kwpv system? I am trying to get the most benifit from my recent pv system install and think this is a good idea, any thoughts?
Discuss Can i power my immersion heater from my 4kw pv system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Yes you can, go to www.parsonsswitch.com they will supply you with a replacement two element immersion heater (1kW & 2kW) and a switch that will turn on the mains to the 1kw element only when the inverter is producing 1.5kw's so will not effect the pv meter reading.
I cannot suggest you any better option than to visit this site www.snhtradecentre.co.uk. Thwy will deliver the demanded information.
Reply to Can i power my immersion heater from my 4kw pv system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
