Can I put a single socket next to a radiator? | Page 2 | on ElectriciansForums
Discuss Can I put a single socket next to a radiator? in the UK Electrical Forum area at ElectriciansForums.net
jack-96
London
Hi guys,
I am a DIY electrician and I need some electrical safety advice. Due to space constraints, I am looking to potentially put a single switched socket next to a wall mounted oil filled radiator.
My concern is the heat from the radiator melting the proposed socket creating melting plastic fumes. The socket would be located 11cm away from the radiator on a wall return. The proposed socket is shown in the image below:
[ElectriciansForums.net] Can I put a single socket next to a radiator?
Is it ok to do this, or would you advise against it?
Thank you!
Reply to Can I put a single socket next to a radiator? in the UK Electrical Forum area at ElectriciansForums.net
