Can. I run 3 phase motor off single phase 4 wiresABC | on ElectriciansForums
Discuss Can. I run 3 phase motor off single phase 4 wiresABC in the DIY Electrical Advice area at ElectriciansForums.net
Dilwyn
South. Wales
Can I run a 3 phase motor. Off single. Phase 3 Black wires ABC 1 earth wire. Any info. Would be great thank you.
  • [ElectriciansForums.net] Can. I run 3 phase motor off single phase  4 wiresABC
The cheapest way of running that machine is to change the motor to a single phase one.
Can you list what the nameplate says? Can’t read it in the picture.
Still looking for any info. 3 phase motor so here goes I have a single phase motor running my holroyd 1947 free standing. 4 wheel grinder but I have the 3 phase motor. Can. I connect it up to single phase. I put some photos for you guys. 3 black wires ABC. And a earthwire any questions feel free guys
Try one of these, it is far cheaper than trying to convert 230v single phase to 400v 3 phase for your existing motor.
Reply to Can. I run 3 phase motor off single phase 4 wiresABC in the DIY Electrical Advice area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
