Can I use a 32 amp rcbo on a radial circuit. | on ElectriciansForums
Discuss Can I use a 32 amp rcbo on a radial circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yr ys
Nicosia
Hello
Is it OK to use a 32 amp rcbo on a radial Circuit. Cable size is 6mm2, cable length is about 15 m. There are 4 double plugs on the circuit. Loads are kettle 2.2 kw, washing machine max 2 kw, electric cooker 1 kw.
Cheers
Reply to Can I use a 32 amp rcbo on a radial circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
