Yes well done both of you give yourself a pat on the back!! You have yet again managed to re-illiterate yet again what I and most sparks already know!
To ask again what relevance does any of this pose to someone who we already know is unskilled. The correct and ethical thing to do was refer the op to a qualified competent electrician, and yes the solutions are all valid and I am in agreement with them, however It's for the installer to make these calls
It was you that started this, Ristard asked you what reg and you got the hump.
If we were to all go by your last statement then there is probably no point in having this forum at all, we were only discussing whether or not the install could be done.
Hey mate power is only 2.5kw so only roughly 10A, you will probably be ok on a 13a plugtop, most little welders are, only issue may be tripping on startup if you have mcbs if you have cartridge fuses or rewirables then it will definately be fine, with welders you will only use that power if you are welding thick steel for extended periods really, i have a welder thats bigger then that (185A) and its never blown the 13A fuse in the plugtop. It never blows the B type MCB either although my mate has one that does occasionally. Give it a try and see before you spend loads of money!
can my house take it?
Australia
Ciarian Abbott,
somersetsparks,
