Can someone clarify this please...Part Pee | Page 2 | on ElectriciansForums
Discuss Can someone clarify this please...Part Pee in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
So I was on a small job today changing a consumer unit and they customer just a few weeks ago had a brand-new luxury bathroom / showroom done by a local plumber. The plumber fitted all new LED lights , 2 new mains towel rails , electric shower and new shaver socket. No testing done whatsoever and no RCD present at the time was was an old re-wireable fuse box.
I told the homeowner this wasn't acceptable. They rang the plumber who I spoke to on the phone and he was adamant his work was fine and its the homeowners responsibility to comply with Part Pee and not his!!!! So I did some looking on the interwed and apparently he is correct, It is the homeowners responsivity to inform building control. And if a penalty notice / proscution was issued agains the work it would be the Homeowner liable for the fine and not the plumber who did all the work.
Is this correct ?
I would argue that the plumber is not correct, that we are liable for the failure to notify and not the home owner.
I've looked into this and having read the approved document a few times, unless I'm much mistaken, the wording implies that the "persons intending to carry out the works" are responsible for ensuring things are notified and compliant.
Since we are intent on carrying out the works I would say that puts the responsibility firmly with us.
Just playinging devils advocate
If the homeowner asked the plumber to install XYZ and the plumber said 'okay I will install XYZ under your instruction but YOU need to notify the council'
As has been pointed out... it's the usual mess of badly worded garbage that lacks clarity regarding the actual responsibilities.
What a ridiculous, but probably all too common scenario. Builders, plumbers, kitchen fitters, handymen etc, happy to do unregulated, uninsured and unsafe work. Customers (the general public) are grossly uninformed about what should (and who should) be doing this work.
Ultimate responsibility lies with the owner of the property. Person carrying out the work and the owner must ensure that building regulations are complied with. It is the owner who would be served with any enforcement notice, if the work does not comply with the regulations. Peron carrying out the work, can be prosecuted in Magistrate's Court (sections 35 and 35A of the Building Act 1984).
The only enforcement notices I've read about, are in regard to large projects, I've never read such about as in this instance.
Is this correct ?
What's the standard of his work like ? Other than the obvious lack of RCD.
I'm assuming he knew that the CU was getting changed, so basically he knew that his work was going to be tested.
Thats fine as long as the plumber/contractor issues the necessary certification to the homeowner for the homeowner to notify the LA within the specified timescale (30days) within Part P.
I've often wondered what would happen if they didn't? Can't see my LBC give a damn.
Exactly , I could do a board change tomorrow hand the homeowner a scribbled EIC and say please submit this to the council for PartPee
If they don't , then what....?
We all know that no one, LBCs included, is going to give a flying about EICs until there is a fatality or other very serious incident at the property in question. It's all about a signature to pin the blame on.
Living in the rural area that I do, a good proportion of the work I have done is on jobs where no planning permission has been applied for, with the home owner preferring to rely on the soon to be abolished 'four year rule' instead, so it wouldn't go down too well if I submitted paperwork to the authorities.
Agree. However, as been said before, it can put off potential buyer’s should you try to sell your house.
No one cares about that in the real world
I have brought 2 houses with missing paperwork one a missing Fensa for windows and one a missing cert for a small extension
60 quid a pop for a indemnity and everything went through without a hitch
You could ask for some cash for Not submitting any paperwork 😄
I think building a property or an extension without planning or notice, is something LBC will go after, depending on its impact.
All an indemnity policy will cover is the legal action. If it’s found against you, it doesn’t include the cost to put right.
When I sold my house a few years ago, I only had one interested buyer, who was (or his solicitor was) very interested in my Compliance docs.
That said, no one would give a scobby about a bathroom refurb with no Part P.
Reply to Can someone clarify this please...Part Pee in the UK Electrical Forum area at ElectriciansForums.net
