Guest viewing is limited
Lots of things. It can smooth the bump of a rectified waveform.
It can block DC.
It can be used in conjunction with an inductor to reduce EMI.
And ashit ton of other stuff.
Why the "once and for all"? Has this been on your mind for a while?
There are different ways to look at it, but one analogy is:
  • Capacitors try to prevent voltage changing
  • Inductors try to prevent current changing
So when you try to increase the voltage across a capacitor you need to put current in to charge it, this makes it hard to change voltage suddenly as the required current is given by I = C * dV/dt so a capacitor provides "smoothing" and stores electric charge in doing so.
An inductor need a voltage applied in order to change the current flow. So if you try to interrupt current in an inductive circuit (e.g. motor, relay coil, etc) you get a high voltage generate opposing that. The voltage is given by V = L * dI/dt and that can cause damage to switches or solid state controls, but is sometimes of use in cases such as car ignition coils.
The rate of change terms (dV/dt and dI/dt) for the useful case of a sine wave is given by 2 * PI * f which leads to the concept of capacitive and inductive reactance, analogous to resistance in opposing current flow, but not in-phase with the voltage as it is the changing aspect that matters. That is at its maximum when the voltage is crossing zero.
here endeth the first lesson.
Yes but can I use capacitors to increase voltage across motor windings?
It can block DC.
If I had a capacitor across a winding in a three phase motor, then what difference would that make?
Yes, but not in any sane way.
Usually a capacitor is used with a motor either to phase-shift the supply so a single phase can generate a "rotating" magnetic field, or as power factor correction so the motor plus capacitor is nearly resistive (i.e. PF close to 1)
So a capacitor is used to generate a rotating magnetic field in an electric motor, how?
The current through a capacitor is proportional to the rate of change of voltage across it (I=C.dv/dt). A capacitor in a series circuit can therefore be used to change the phase of the current in that circuit relative to the supply voltage. If you have two identical windings fed from a common AC supply, one with a capacitor in series and one without, the phase of the currents will be different (assuming the capacitor is of a suitable capacitance) and so will be the phase of the magnetomotive forces and hence fluxes created by the windings. Place the two windings mechanically at an angle to one another in the motor and they will create a rotating flux. The radial axis along which the peak flux passes will progress around the stator, first aligning with the capacitor winding then with the non-capacitor winding, repeating for each half-cycle of AC.
Yes. However many windings are in use, either two or three, they should all receive a sinusoidal current where the relative phase angles correspond to the physical angles of displacement of the coils around the stator in electrical degrees (which may be a multiple of the number of mechanical degrees, depending on how many pole-pairs the motor has.) Single-phase capacitor motors typically have two windings not three, in which case the currents might be arranged to differ by 90 electrical degrees i.e. a quarter of a cycle. A 3-phase motor re-purposed to run on single-phase by adding capacitors, should be arranged to receive three peaks 120 electrical degrees apart, as per a normal 3-phase supply.
London
Electrical Enthusiast (Unqualified Hobbyist etc)
Can someone once and forall tell me what a capacitor does in an AC circuit?Thanks.
Pcg127,
Pcg127,
