Can this be done..... ? | on ElectriciansForums
Discuss Can this be done..... ? in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Chaps...
Running sub main to shed - SWA.
Can the plumbers put his alkerthene (dodgy spelling there I know:cheesy:) pipe in there also ?
Any reg on this, spacing required etc....?
Thank you,
Sy
in all honesty, i dont see a problem. its not going to be at a pressure that will damage the cable, and if the pipe does get damaged, then its likely that the cable will have been damaged at the same time anyway. im expecting flak for saying this, but i would.
Thought it would be fine.... just nice to have another opinion, or 2 or 3 - thanks as usual chaps :)
Plumber is a mate of mine so is digging trench, sand in, cable in and marker taping (wonder if he'll make off both ends also for me:devilish:)
Thought it would be fine.... just nice to have another opinion, or 2 or 3 - thanks as usual chaops :)
he will probably make it off into a sink. what use is a cable with a tap on each end?
spacing factors generally apply to bunched cables in trunking ect, i cant recall any regs which require space factor needed in this situation especially underground as the ambient temp will not rise to excessive levels
Hi Marie-Claire , if my memory had been on the ball i think it would have been more to do with segregation of services rather than temp dissipation ,
Having said that , do be carefully if you ever do speck a buried cable as you will have to take account of it and down rate it's load carrying ability more than a suspended one .
Reply to Can this be done..... ? in the Australia area at ElectriciansForums.net
Are there long pipe runs ? Although not a legal requirement, the HSE recommends hot water should be delivered at 50ÂşC within 1 minute to help...
