Can this be done..... ? | Page 2 | on ElectriciansForums
Discuss Can this be done..... ? in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Chaps...
Running sub main to shed - SWA.
Can the plumbers put his alkerthene (dodgy spelling there I know:cheesy:) pipe in there also ?
Any reg on this, spacing required etc....?
Thank you,
Sy
Hi Marie-Claire , if my memory had been on the ball i think it would have been more to do with segregation of services rather than temp dissipation ,
Having said that , do be carefully if you ever do speck a buried cable as you will have to take account of it and down rate it's load carrying ability more than a suspended one .
im thinking off the top of my head but im pretty sure ambient temp has to be taken into consideration in most cases of installing cables and i dont know what the pipe is that the swa is next to and if there is warm/hot water passing through it
Actually there are thermal derating factors applied to LV multi core cables buried over 600mm either direct buried, or in ducts!!
Also on the bigger projects, where pressurised water mains are buried, that require ''trust blocks'' at changes of direction, ...then it is not permitted to run electrical services in the same trench or near that trench come to that!! . In fact it would be very foolish to do so, if anyone here has seen what a burst 10'' pipe at or on a trust block can do!!!
For buried cables and those buried in ducts etc, Regulation 433.1.4 requires a factor of 0.9 to be applied to the current-carrying capacity (Iz) of the lowest rated conductor in the circuit protected :
In ≤ 0.9 Iz
Reply to Can this be done..... ? in the Australia area at ElectriciansForums.net
Are there long pipe runs ? Although not a legal requirement, the HSE recommends hot water should be delivered at 50ÂşC within 1 minute to help...
