can two 6mm csa cables each with 30A mcb in joined at 50A dps to supply 9.5kW shower | on ElectriciansForums
Discuss can two 6mm csa cables each with 30A mcb in joined at 50A dps to supply 9.5kW shower in the UK Electrical Forum area at ElectriciansForums.net
M
mikejd
Hi I have two 6mm csa cables in the loft each going back to a separate 30A mcb in the CU. One is redundant, the other goes to a broken 8.5kW shower. I want to fit a new 9.5kW shower and would like to join both 6mm cables together at a 50A dpst shower switch, then run a short length of 10mm csa cable from the switch to the shower. Can anyone see a problem with doing this. Both 6mm cables are approx same length (12m), there is a RCD in the CU.
Re: can two 6mm csa cables each with 30A mcb in joined at 50A dps to supply 9.5kW sh
what do you think mikejd?
what can you see as the down sides to doing it this way....if any?
get a 8.5kWatt shower instead. use 1 6mm and keep insulation out of the way. sorted.
2x 6mm cables wont fit into 50a switch terminals. better get a small din rail equipped enclosure and join them on a 100a isolator.
What ya gonna put on your test sheets?
This is no word of a lie .... I was once presented by a receptionist of a log-cabin park a piece of A4 lined paper that said ....
Circuits :
Sockets - Passed
Lights - Passed
Cooker - Passed
Appliances :
Fridge - Passed
TV - Passed
Kettle - Passed
Microwave - Passed
Toaster - Passed
That was when i was working for my dad before he retired, towards the end of my apprentership - The receptionist had apparantly told him if he wants to rent his log cabin out during the summer he's going to have to get an electrical test done on it - and he presented her with that lol. That's when we were called on his behalf.
Maybe the OP has something similar in mind, lol.
Reply to can two 6mm csa cables each with 30A mcb in joined at 50A dps to supply 9.5kW shower in the UK Electrical Forum area at ElectriciansForums.net
