can u name these earthing arrangements from domestic properties??? | on ElectriciansForums
Discuss can u name these earthing arrangements from domestic properties??? in the Domestic Electrician Forum area at ElectriciansForums.net
E
electrophile007
hi folks can you please help with identifying these earthing arrangements?
thanks ;) image 1
image2.JPG2
image3.JPG3 image4.JPG4image5.JPG5image6.JPG5b
note image 5 b is the c/u for MEA 5 is this safe with no RCD???
Why don't you start by telling us what ''YOU'' think are the earthing arrangements to these photo's?? Though how you expect to determine the earthing arrangement from looking at the internals of CU's is another matter altogether!!
1 = No earth although it has a PME head. The gas pipe is to close to switch gear, may need to sort that one out.
2 = PME but badly done.
3 = Cant tell.
4 = PME with really bad painting.
5 = It's a CU?
thanks ;) image 1
View attachment 285113 View attachment 285124View attachment 285135View attachment 285145b
BYPASS, report ASAP.
Im not sure as to the arrangements.
image 2 gave a ZE of 123 ohms and IPF 1.66KA so im thinking TT
image 3 gave ZE 0.25 Ohms IPF 1.97 KA and ISC 1.46KA so im thinking PME
image 4 ZE 190 Ohms and IPF 128KA so im thinking TT again
image 5 and 6 are the same location ( newbuild block of flats about 10 years old ZE 0.25 Ohms IPF 0.905KA ISC1.36 KA so im thinking PME however there is no RCD at the C/U would this be unsatisfactory if a EIC report was done???
thanks for all your input by the way folks ;)
Reply to can u name these earthing arrangements from domestic properties??? in the Domestic Electrician Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
