View the thread, titled "can u name these earthing arrangements from domestic properties???" which is posted in Domestic Electrician Forum on Electricians Forums.
E
electrophile007
hi folks can you please help with identifying these earthing arrangements?
thanks ;) image 1
image2.JPG2
image3.JPG3 image4.JPG4image5.JPG5image6.JPG5b
note image 5 b is the c/u for MEA 5 is this safe with no RCD???
Just because there's a PME head there it doesn't mean the link is there mate. I though TT because there's no cable going to it
Apart from the grey one I wouldn't have said they were PME heads, the black ones with added earth terminal are normally found on split con TNS supplies around here.
I'm pretty sure the DNO would not have fitted the earth terminal if they weren't providing an earth.
This is how my flat is supplied. Although it is fed the main incomer in the basement which is TP&N, PME.
Reply to the thread, titled "can u name these earthing arrangements from domestic properties???" which is posted in Domestic Electrician Forum on Electricians Forums.
