Hello,
Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm knockouts. Is there an adapter that fits a 25mm conduit in to a 20mm back box? Can i cut a 25mm hole in the back box? Do the 20mm male adapters allow for 25mm conduit to go into 20mm back boxes?
You can get pvc reduces that allow 20mm to fit into 25mm setups, I am not sure but I assume you can get the reverse option too.
Are you using 25mm for the amount of cables in the conduit? If so, it will be tricky to get them through anything smaller.
The hole in the adaptor through the threaded section will be even smaller than the conduit size. So even smaller than 20.
Either back boxes with 25mm holes already, drill the holes out bigger or reduce the conduit size.
It might be tricky to "drill" (i.e. holesaw) out any exsiting knock-outs without it coming to a messy end as the cetre bit decides it is being knocked out. If you get a 25mm hole punch it can open out an existing 20mm hole much more easily and neater.
As above, look at Q-max punches. I have a 20 and 25 and they are excellent bits of kit.
You drill a small hole, assemble it like a nut and bolt, tighten up and get a very clean hole.
(I often use the 20 punch, a galv coupler and bushes and a metal surface fused spur if adding outside lights and it’s a metal CU with no knockout in a convenient place)
I have bought Q-max punches before from both of these places:
However there are other places you might find them, not always as good value or in-stock:
I don't think the OP has mentioned specifically which type of box is needed - PVC, steel surface or steel flush. Obviously if it's PVC, a holesaw or step drill goes through it in seconds with minimal risk of splitting, even if you're in the original 20mm entry. The Q-Max punch is best for steel, but if you have to use a holesaw and either the pilot drill or the edge of the saw is within a knockout, you can help prevent it detaching by clamping a small piece of plywood or similar behind it, although the clamp tends to get in the way of the drill.
Not sure which way is required, 20 to 25 or 25 to 20, but a 25mm TRS gland often has the stuffing part with a 20mm thread. Discard the stuffing nut and the rubber compression seal, and you have a neat female 20mm to 25mm male adaptor.
England
Can you fit 25mm conduit to a 20mm back box?
laurence1995,
ipf,
