Discuss Can you help me install a fixture using a screw terminal block? in the DIY Electrical Advice area at ElectriciansForums.net
Yes. Show a pic if you can when you have done it.Yes, so I put the ground wire in the opposite side as the one that is already in there and put the blue wire and white wire in opposite sides and the same with the brown and black?
Reply to Can you help me install a fixture using a screw terminal block? in the DIY Electrical Advice area at ElectriciansForums.net
