Can you help me install a fixture using a screw terminal block? | Page 2 | on ElectriciansForums
Discuss Can you help me install a fixture using a screw terminal block? in the DIY Electrical Advice area at ElectriciansForums.net
No they do not line up at all.
To be honest I don't know what else to advise.
Reply to Can you help me install a fixture using a screw terminal block? in the DIY Electrical Advice area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
