T
tom79bmth
Just a quick question as title says are you aloud to install a sub main for a house inside the outside meter box, they are meant to be waterproof ??
Discuss Can you install a sub main in a meter box in the UK Electrical Forum area at ElectriciansForums.net
nien nien sir!!...OK understandy now, lol!!
If you have enough room in the external meter cabinet, there shouldn't be a problem, though you'll need the DNO to connect the switch fuse to their supply.
nien nien sir!!...
the energy supplier to their metering equipment...
would you say this was a true statement?Hi thanks for your reply just that DNO guy said your not allowed but what do they know, I have done it a few times in the past when I was apprentice with my old company and couldn't see a problem with it but the dno guy told the customer and the dno I always right in there eyes
It,s a tncs system all earthing is correct
it's not going to be concealed cable but I prefer to run in swa just because of the load rather than use t&e and separate earth
Thanks for your help
sorry eng...i couldn`t help it...lol...OK, whoever then!!
I get totally confused with who's responsible for what, since the disappearance of the Regional Electricity Boards, in favour of the private companies... I would have thought the switchfuse was installed ''After'' the meter equipment rather than before??
Besides, a switchfuse should have been provided by the energy supplier if it is/was known at the design stage, that the tails are going to be over 3 metres in length, after all it's their rule. (for want of a better word!!)
exactly....its a farce...This is something that baffles me.
The householder pays for the box and the DNO/supply companies think they can dictate what is installed in the box.
do you think that an SWA negates the use of RCD if the cable was buried within walls etc?
lol....the point i was making was that generally an SWA should be the cable of choice..Yes if is in the correct zones and is a sub main, or am wrong and why ???
Reply to Can you install a sub main in a meter box in the UK Electrical Forum area at ElectriciansForums.net
