Can you login ElectriciansForums okay since the change in Ad Network? | Page 7 | on ElectriciansForums
Discuss Can you login ElectriciansForums okay since the change in Ad Network? in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
[ElectriciansForums.net] Can you login ElectriciansForums okay since the change in Ad Network?
Just checking that you can all login okay since we've switched Ad Network provider. If you can't login, you should be able to reply to this article as a guest, give us your username and we'll take a look. Failing that, email us on [email protected].
Dan
Hang in there mate, I'm working on the settings until it's done. Been at it for a week or so with plumbers and that's alright now. For the time being you can use an ad blocker if you want mate. Or just hang in there. Your account status would be one of the first I sort out as it's of the highest here, and you're a patron to boot. :) Can't have you watching bake-off lol
Edit:
@DPG try now for me pal. Should have gone?
Edit edit:
No it hasn't mate I've just tested it. I'm gonna need more time else I'm going to screw up something if I rush it this late.
Cheers for the reply!
Thanks Dan! No I can't. Brave browser.
Am swamped with multiple projects recently... ? Will be checking out things thereafter, thanks.
David
the one with the catchiest username ?
I guess as I'm not responding as a Guest I must have successfully logged in. Although it still says "Log in" in the top menu rather than "Logged in " I was expecting.
Dan
Phew! thought I had a problem but found it was my fat finger on the keyboard mistyping the password. All OK here now, thanks.
Reply to Can you login ElectriciansForums okay since the change in Ad Network? in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
