Can you supply a cooker extract hood off a cooker switch? | on ElectriciansForums
Discuss Can you supply a cooker extract hood off a cooker switch? in the UK Electrical Forum area at ElectriciansForums.net
Not used to domestic installations so I'm unaware of many of the regs. Can you spur off the cooker switch to feed an oven extract hood?
TIA
you can but should fit a FCU with a 5A fuse to protect the cable to the hood, (subject to manufacturers instructions).
TIA
The only requirements in Bs 7671 2018 which are specific to domestic installations are that lighting circuits require additional protection by means of an RCD and distribution boards must be of fire containing construction. Otherwise the general requirements apply.
Reply to Can you supply a cooker extract hood off a cooker switch? in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
