Simon_
I have my elecsa assessment coming up at the end of July (my first) and I was going to fit a new CCU for my in laws which will be replacing old wylex fuses and possibly a rewire. This job is now not convenient at the moment for the assessment. With me being a new business and work isn't exactly flooding in at the moment would you suggest cancelling/postponing til a later date? I've done a few jobs but they were only minor things like changing lights/sockets so far.
You need to talk to Elecsa but I think that they want to see a substantial job for evaluation so it may be better to postpone it. Depending on the notice given they will probably want to charge. Good luck.
That's what i thought. I've just looked on the paperwork and if the cancellation is within 21 days of the assessment, they will charge.
yeah agree with amp. ! if you rent mention to your landlord your willing to provide him with a free upgrade. prob work out cheaper than cancellation. If you dont rent and you got a Good CU board already.....Change it anyway..Still cheaper no doubt..think it like over 200 to cancel.....There nothing wrong with doing your own property. Elecsa are very cool and understand your scenario and all they want see is that your competent
The CCU doesn't really need changing but I am putting downlights in the kitchen of my house and was thinking of replacing the lighting MCB for an RCBO as it isn't RCD protected. Would that still be enough for elecsa?
what is your CU config. if it's to 16th with 1 RCD, then replace it with a dual RCD board. then do a full EIC. then you will have your lighting RCD protected and a major job for elecsa.
I doubt it, much better to change cu to 17th as telectrix suggests
It ll be much cheaper to swap your board then cancel, Im sure its somat like 250 notes if you cancel
If you cancel how would you deal with any notifiable work that you asked to do? Surely you don't want to be in a position of having to turn work away do you?
Replacing your own CU would be the best course of action IMHO
Call elecsa and ask if they'll move it.....I've had NIC move a couple before and they do understand if it's not your fault. I've not been charged if you call them and ask....likely they'll waive. You must be outside of 21 days anyway?
You'll need a decent job to show them so a full CU change would be better anyway.
Meantime, you can still do notifiable work.
Last sentence, how exactly?
If its the first assessment then the member is not registered. Yes, you have 30 days to notify but without a date for the assessment how can you judge the 30 days.
Use the green forms....you are going through the registration process anyway and it's allowed. May just be NIC but I can't see why it would differ.
Just put the installation date on the certificate and notify as soon as possible afterwards?
[Edit] Sorry, was rushing out for a mo'. What I mean is do your best with what you can. The certificate date is important but I can't imagine missing a 30-day notification period would be a shooting offence if you're in the process of registering. "Best endeavours" would be quite acceptable.....certainly compared to DIYers, no-registered electricians and so on.
I cancelled my niceic two days before.....£290+vat it has worked out cheaper to right it off and join napit due to labc checking the two jobs before the assessment!Niceic did explain it only has to be two notifiable jobs so I would honestly get your regs out and go down the notifiable job list and pick the easiest job you could possibly find at someones house for free!......alternatively get the yellow pages out and phone round the sparks asking if you could come round and work a couple of days for free in return of you being able to use that site for assessment.......I got 3 rewires on now in merseyside come fit a board on one of these on you could use that by all means if you are local enough and that would help you, Don't make my mistake and dwell on it tho as I say I left it untill two days before......I should have my part p now instead I have to wait a couple of weeks for napit now!
Cancel elecsa assessment/postpone help
Business Related
Simon_,
p11jor,
