can't believe what i saw today | Page 2 | on ElectriciansForums
Discuss can't believe what i saw today in the UK Electrical Forum area at ElectriciansForums.net
crow11
Hi all not posted for a while been busy and going through a divorce:hurray:
been to a job today to fit alarm system, in a new build just been finished,
opened c/u to find neutral tails done in 10 x 2.5mm singles all crammed in and earth done in about 6 x 2.5mm singles,
these run for about 6 meters from isolator at the front of the house then through the house to c/u, can't see where or how they are run.
Then i go into the detached garage to find a 2 way c/u on the wall with 100A main switch, but i didn't see anything at the house c/u for garage, so after a good look around, finds the swa from garage going into an adaptable box at back of house connected to the back of a socket on the downstairs ring, and where the swa goes into the garage they have bent it at that much of an angle all the outer sheath as split,
so i asked to look at the cert for the house and they can't even get that right got the mcbs listed as 10ka instead of 6ka, so i am guessing everything else is made up,
the owners have had a word with the site supervisor and he is getting 1 of the electricians to come round and have a look, because he can't take another electricians word for it lol
Reply to can't believe what i saw today in the UK Electrical Forum area at ElectriciansForums.net
Well conventional wisdom says that you just parallel ('piggy back') as many switch sources as you need, all fed to the contactor coil. If for...
Sounds more positive.
