cant drain Combination cylinder to change the immersions ???? | Page 2 | on ElectriciansForums
Discuss cant drain Combination cylinder to change the immersions ???? in the Australia area at ElectriciansForums.net
B
bgec
Hi all
I know im missing something here, i cant see a drain off tap or any way of doing it. I thourght i got it undone the immersion and got soaked not to metion the panic in the loft that the nice new room below was ruined. I cleaned up and made my excuses and left. I do have to go back tommorow and get this done so any help would be great.
Yes, thinking about my combination tank,thats exactly right
Draining the hot water doesn't lower the outer tank water level
There would probably be a self screwing drain off attatchment available, I would expect, for this situation
Alternatively there is the plumbers forum,but be prepared to get:hanged:
I tried it once........got banned
Basically, you are not going to be able to drain the tank.
If you turn off the feed to the cold water tank in the loft, it will only drain to the bottom of THAT tank and leave the cylinder full.
If you turn off the feed FROM or TO the cylinder, all you will do is stop the hot taps from flowing.
Im assuming gravity fed.
okay, undo the outlet pipe, insert hose pipe and syphon!
Having read through the thread, at long last some sense! Old tanks wont have a drain point, a siphon is the only way! Drain all the water from the header tank first by turning off the feed to the header and opening the hot taps. Then it’s a load of old blankets to mop up when you undo the top pipe to get the siphon pipe in.
I just hope you know how to set up a siphon for quick use, there’s no need for rushing down stairs to suck on the end of the pipe!
Have you thought about fitting a drain off valve using one of the pipe freezing kits you can buy from most plumbing wholesalers. The last one I used, I think it gave me about half an hour to get the pipe work done
As has been said turn off the cold supply turn on the hot taps till the header tank empties, this will still leave the hot cylinder full and probably the header supply pipe too. .If there is not a drain cock at the cold supply pipe at the bottom of the tank crack open the vent/hot supply pipe at the top of the tank and using your ingenuity capture the water that will escape (supply pipe will be full and header may not be quite empty) Then do as Mark says, you could even buy a small whale type pump and pump enough out to let you remove the element.- Or in desperation you could cut the cold supply pipe at a level above the cylinder (if you have room) loosen the union at the bottom after attaching a hose at the cut pipe then rotate the pipe to allow the water to flow from the hose. when complete join pipe with a connector. (bit messy but works) If the cold supply pipe does not clear the top of the cylinder you can't do it this way.
Took me that long to type ,you beat me to it.
Reply to cant drain Combination cylinder to change the immersions ???? in the Australia area at ElectriciansForums.net
