Cant get a Zs reading ? ? ? | Page 2 | on ElectriciansForums
Discuss Cant get a Zs reading ? ? ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I cant get a Zs reading from the majority of my new circuits. I do get a reading between the incomers to the d.b and the main earthing conductor and I can get the RCD tripping. The system is TT and its a total rewire. Any help would be appreciated.
Go back to the beginning. You get a Ze reading between incommers and main earth. I presume this is using the normal Ze measurement. Can you get a Ze measurement between incommers and main earth using the RCD function?
If the answer is No then you have a meter problem. (The only difference is the way your meter is measuring Ze; one way it works, one way it dosn't). Solution: use a calculation for Zs [= Ze + (R1 + R2) ]
If the answer is Yes then you have a connection problem. If you get a Zs measurement on the RDC input terminals, but not on the RCD output terminals (using the RCD function in both cases) then its the RCD. If you have a Zs measurement on both sides of the RCD then progress through the circuitry until you don't get a Zs measurement. That will tell you where your problem lies.
I will give that a go mate. I think I just leave my meter on the no trip function out of habit as nearly everything has rcd's now.
Reply to Cant get a Zs reading ? ? ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That 'stranded 2.5mm' was probably imperial 7/.029 which is about 2.9mm2. Which might account for expected readings being different.
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
