Cant remember studying this but if anyone can help me out that that would be sweet
L
lofty84
Hi im reviseing for my 203 and this question has got me stumped its a bit hard to draw it out exactly as tthe lines do not match up but its basically two lines that form a right angle with an arrow head on the end of them.
Its quite hard trying to remember things as if you failed an exam you just moved on as the resists weremonths away. Haveing got through everything else it would be nice to get this one under my belt so its just the 301, 302, and 303 to do but I dont remember looking at things like this.
_ _ _ _ _ _ _ _ _ _ > I ref
|_|
V
V (this is the letter V)
the possible answers are
a. purely resistive
b.purely capacitive
c.resistor and inductor in series
d.purely inductive
the answer is b (purely capacitive) but why is this is the picture supposed to be showing me something
thankyou
Re: Cant remember studying this but if snyone can help me out that that would be swee
Heres another that I cant remember howto do
A transformer takes aload of 25 KVAat a power factor of 0.8.calculate the input power in KW
a.31.25 KW
b.200 KW
c.20 KW
d.312.5KW
The answers c. 20 KW
Ive worked out that 0.8 x 25 is 20 but how come you do it this way instead of say doing 25000/0.8
KW - KVAxPF = 25x0.8 = 20.
Upvote 0
I cant beleive this lol ten questions in and heres the third one im stuck with.
if a 8 kw motorwith a power factor of 0.9isconnected across a 400v supply, calculate the current taken by the load ?
a.20 A
b.22.2 A
c.2.88 MA
d.2.22 A
the answers 22.2A and I guessed right but I wouldnt mind knowing how to do the calculation
I had to get my notes out for these - reactance I can do, but I struggled with this.
P
I = --------
V x pf
8000
I = -------------
400 x 0.9
I = 22.2A
Upvote 0
What about root 3 (1.732) ???
Upvote 0
That would give an answer of 38.5A, which wasn't one of the options.
I seem to remember 3 phase supplies have to be treated differently but the question just stated it was a 400v supply with no mention of 3 phase, so I didn't want to over-complicate the issue.
Upvote 0
Thanks to everyone whos tried to help me. Really is much appreciated.
in regards to the sq root of three the 1.732 does that only comeinto play on three thase systems ?
Upvote 0
yes you are right only in 3 phase
Upvote 0
The voltage supplied to the primary winding of a step down transformer is 660v and the output voltage is 230v. If the primary current is 12A the value of the secondary current will be.
Would the answer be 660/230 x 12 = 34.4
Upvote 0
Is= VP*Ip/ Vs 660 * 12 =7920 / 230 =34.4
Upvote 0
This isnt looking good but at least ive given myself a chance by starting the revision early
How many numbers of turns are needed on a transformer if the primary windings are 1000 and the primary and secondary currents are 5 A and 20 A respectivly.
the options are
a. 200 turns
b.250 turns
c.100 turns
d. 50 turns
the answers b and i did come to that conclusion but was the way i did it right.
I said 1000/5 = 200
and 1000/20= 50
I then addedthem together
The way to do it is with ratios if the number of turns increases 5 times then the voltage increases 5 times. Hower with transformers it's the opposite way around with I and V, if the current increases by , say, 10 times then the voltage decreases by 10 times - and vice versa.
In your example the the current has increased from 5A to 20A (20/5 =4) so it has increased 4 times.
That means the voltage must decrease by 4x . Also that the number of turns has decreased by 4x.
so 1000 turns /4 = your answer (250 turns) hope that helps a bit:)
Upvote 0
How do you get the input lower than the output think you will find the answer is A
the input power is in kw and is just the power dissipated in the resistance, whereas the apparent power kVA takes account of the current used to generate magnetic fields as well. (It is the hypotenuse on the triangle so will be bigger than the adjacent)
It is not like saying you are getting out more power out than you are putting in.
The extra current for the apparent power is still there and this is why you have to calculate your cable size on the apparent power not the true power with inductive loads.
This is why there are always so many questions/problems on here when people are working with inductive lighting - they do there calcs with the power (kW) not the apparent power (kVA).
edit: the correct answer is c.
Upvote 0
Thanks to everyone who has got involved and helped me out.
If anyone knows how to tackle some of the harder unanswered ones it would be really helpfull
Upvote 0
couldn't find any that were unanswered...
It is probably worth you remembering this-
" the kVA figure (apparent power) will always be bigger than the kW figure (true power)"
the only exception is if the the power factor was 1 (unity) and then they would be equal.
Upvote 0
Im back with some more which are confuseing me
1. A resistor and n inductor in a series circuit have a resistance of 6 (ohms) and an inductive Reactance of 8 (ohms) respectively. What is the total impedance.
The answer is 10 (ohms) but 8 + 6 is not 10
2. A transformer has a turns ratio of 400:4. If the supply voltage is 400v, what will be the secondary voltage
The answers 4 ,so does this mean that if it said it had a turns ratio of 400:10 and the supply voltage was 400v the secondary voltage would be 10 ??
Upvote 0
heres a weird one
what is the power factor of a circuit with a capacitor connectd in series, given the resistance is 6 ohms and the capacitive reactance is 8 ohms
answers are
0.6 lagging
0.75 leading
0.6 leading
0.75 lagging
completely stumped on this one
Upvote 0
1.
Z = √(R² + XL²)
Z = √(6² + 8²)
Z = 10
2. The figures given are nice and easy to understand, ie 1 volt per turn, so yes if the turns ration wer 400:10 the secondary voltage would be 10.
Upvote 0
lofty84,
w crane,
Electrical Courses
