Dustydazzler
Climate change: Ban new gas boilers from 2025 to reach net-zero
A ban on new gas boilers from 2025 is one step to reach net-zero emissions by 2050, say energy experts.
thoughts ...?
I read somewhere that Rolls Royce are experts at micro nuclear plants... and that we'll probably have several of these... regardless of what the 'Greens' say.If the 'greens' have their way there will be no nuclear.
I heard somewhere that they are already looking into all that... the biggest problem with hydrogen in plastic pipes is that the molecules are so small... you get alot of leakage ! Anyway... that's all being looked at and is already a workable solution I think... just needs to be 'scaled'.so is the UK domestic gas network capable of flowing the vastly increased amount required without major upgrades?
The issue is less to do with modern house builders and more to do with the woefully low standard of building regulations. As soon as the Regs are increased to the level that you or I would build to, if we were building a house for ourselves... the sooner we'll start to build decent housing !The more astute may sense that I don't think much of modern house builders
They have improved massively - but there's still room for improvement.The issue is less to do with modern house builders and more to do with the woefully low standard of building regulations. As soon as the Regs are increased to the level that you or I would build to, if we were building a house for ourselves... the sooner we'll start to build decent housing !
The are, Small Modular Reactor technology based on the reactors powering nuclear submarines with a few more innovations.I read somewhere that Rolls Royce are experts at micro nuclear plants... and that we'll probably have several of these... regardless of what the 'Greens' say.
this Is crazy, my house was built in the 1920,s with solid walls and draughty floors, a heat pump is never gonna work?
surely hydrogen boilers have got to be the solution
Didn't we used to use hydrogen years ago ? Wasn't "town gas" mostly hydrogen ?And that's uf you ignore "minor" issues like the fact that hydrogen leaks through most materials and turns steel brittle.
Coal gas contains a mixture of calorific gases including hydrogen, carbon monoxide, methane, ethylene and volatile hydrocarbons together with small quantities of non-calorific gases such as carbon dioxide and nitrogen.Didn't we used to use hydrogen years ago ? Wasn't "town gas" mostly hydrogen ?
I caught a bit last night on the news... apparently... Orkney is in such a situation and they do exactly that... using surplus 'green' electricity to make hydrogen.If you have massive amounts of "spare" CO2 free lecky - which no-one in the world does - then you can electrolyse water into hydrogen & oxygen.
And do they have enough surplus that they never need the backup (I'm guessing, diesel) generators ?I caught a bit last night on the news... apparently... Orkney is in such a situation and they do exactly that... using surplus 'green' electricity to make hydrogen.
And there's the point where most of these claims fail.Using grid power from the cheapest hours would supplement the system in the winter etc.
