Can't think of the name???? | Page 2 | on ElectriciansForums
Discuss Can't think of the name???? in the UK Electrical Forum area at ElectriciansForums.net
B
bk81
Hi Everyone,
I'm having a mental block!
I'm trying to think of the name of the little copper bar that goes between the load side of a circuit breaker and a crimped cable?
It's for a 2P 63A Type C mcb with bar connecting the switched part so rated to 125A, they have a crimped 50mm cable, it looks like a copper upside down Y with a 6mm or 8mm screwed terminal on
What's the name???
Someone stop me from going mad! :wink_smile:
Cheers
In the Electrical world, use of correct terminology is key, so i will set the record right.
The title for the item of equipment you describe, and that someone has kindly put a photo up, is known as a "Short Stay". Make sure you ask for this at the wholesalers as they will understand what you mean.
Cheers.............Howard.
dont know about `short stay` Howard...
had a lot of fun though sending the works dimmer to the stores for a `long stand`...
glass hammer, a bucket of steam & some welding sparks spring to mind here n all....
I found one!!!!!!
My work makes one for our systems, no wonder cos tryin to find them anywhere else is a nightmare! lol
In my work it is called a 2 pole bridge
[ElectriciansForums.net] Can't think of the name????
Dont want to hijack the thread, but my best one was when i was in the RAF and i sent a new recruit to give a box of bearings to the Senior Navigation School Officer to replace the ones he had lost.
Ah, a 2 pole bridge...... If only you had asked the question more clearly. Like - what's a 2 pole bridge called? I'm certain some of the cleverer ones on here would have been able to give you an answer
Reply to Can't think of the name???? in the UK Electrical Forum area at ElectriciansForums.net
