Capping installation methods | Page 2 | on ElectriciansForums
Discuss Capping installation methods in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I know it's the basic of questions but I'm starting to question how I install capping.
I do much work with it as most work that involes domestic work is usually just for friends or family.
However, Everytime I do it I always think there must be an easier way. I've tried mortar nails through the capping and in the mortar, screws through the capping into plugs and screws just to the side into plugs. All seem to have benefits and negatives.
Any other methods?
Out of curiosity 123, do you run tw&e down those conduits?
PVC/PVC yes, could be twin and earth, Single Brown or Blue, Blue or Brown & Earth, 3 Core and earth. All available on the shelf at any wholesalers, but good luck finding anywhere with 1.0mm T&E.
Dot and Dab is also next to never seen on brick walls in new builds, it's all floated out with sand and cement.
Oh okay. Was just thinking of getting a few cables down a 20mm, suppose you go up to 25mm etc. Apart from the obvious protection from DIY'ers putting up their shelves on a Sunday, why do you do it? Must put the price up.
PS we don't have brick walls over her', block work mostly and the inevitable timber frames.
We have plenty of timber framed builds as well, conduit not used for that.
If needed we add a 2nd 20mm conduit.
If it's a new build I'd bring in a company to track the walls. If it's a revamp or a kitchen etc it's most likely conduits will already be there, so can often be reused. If it's a kitchen install putting a socket in the adjoining unit is frowned upon (generally), either isolators above worktop or all isolators into a larder unit.
For a small amount of water, theirs quite a difference in how we do things and in Northern Ireland we work to BS7671.
So why the conduit?
I'm waiting for our NI (& Ireland) colleagues, who tell us all off and insist on conduit. :)
fixed with robertson square drive screw heads no doubt. i've got some of them just to pi$$ off young sparks after i'm dead and departed this earth. :D:D:D.
Nice to know you guys read my posts
Not sure if this is relevant but I'm at the local club and I need 14 for a full house. Not sure if the regs cover this but appreciate any help guys. And galls sparkychops. Ta.
Reply to Capping installation methods in the UK Electrical Forum area at ElectriciansForums.net
Capping off redundant pipework question. Hi all. I done some work for someone a few years ago and I've been getting paranoid that things haven't...
sammy67
Hi all, Just wanted a bit of advice in regards to a small installation of emergency lighting. I have a fairly long warehouse that needs some...
