capping
T
tedglen2
Hello – I am hoping to get a new ring set up for the upstairs and downstairs of my house. I have spoken to an electrician and he has agreed that I can run all the cable to all the sockets and just to leave 8 inch of wire and he will come and wire them up and fit new consumer unit.
Only problem is, I have asked him what do I cap with cables with within the walls. He said there is no need? He said plaster can plaster over them, or even I could fill them before skim coat?
Is this ok?
i am a bit too .... he just said leave 8 inches on each socket. and make sure to drill holes through joists 2 inch down. is there a max to how many wires i should put through one hole in each joist ?
Give him a call Ted, he's getting the work anyway so won't mind. That way all and any questions you have can be answered in one hit and he's got the feeling you're not wasting his time because he's involved right from the off all the way through.
I'd prefer my clients to do that rather than go to an internet forum mate
lol - you are right, i just didn’t wont to bother him while he at work. is there any where online i can look up regations
You'd need to buy the regs (look up BS7671) but you won't understand much of it........
This book will give a more generalised view "Which?" Book of Wiring and Lighting: Amazon.co.uk: Mike Lawrence: Books It may be at your local library and will include wiring safe zones, where you can drill joists, etc.
But (and i agree with the above) you are supposed to be doing the wiring under the supervision of the person who is going to sign it off as his own work. So he needs to supervise.
Hence my advice to ring the guy Ted. By rights he should be inspecting the cable runs as they pass through the under floor space and up or down the walls before they are covered over by plaster or floorboards, get on the phone. He's the one with his name on the cert, make him earn his money:)
Ted, this electrician of yours. Is he a Part P approved contractor?
The work you have described will need notifying to the Local Authority Building Control.
The work you are doing on his behalf needs to be inspected and tested in it's entirety by the person signing the work off so I would not fill chases or refit any boards that you have had to lift to run the cables.
If for any reason the spark you are using is not Part P registered then you may wish to contact the LABC to arrange them to inspect and test work before ANY work commences, during and on completion.
If this work does not get signed off appropriately using one of the two options available then you may find that you could end up 1) Not being able to sell your home in the future 2) Your home insurance policy may become null in void and 3) Not very likely but you and the electrician completing the work could be prosecuted and fined up to £5,000.
Oh there is always number 4) The risk of the house burning down or risk of serious injury or death if electrical work is not completed as per the very detailed schedule in design, installation and inspection and testing
Good luck:thumbsup
I agree with others, in that you really should contact your electrician direct as ultimately, he will be responsible for signing the installation certificate.
Good luck.
