capping | Page 12 | on ElectriciansForums
Discuss capping in the UK Electrical Forum area at ElectriciansForums.net
B
Buzz-light-bulb
Does anyone know anywhere in the regulations that it states I have to use capping to protect cables when embedded in plaster as I am currently on a rewire, it says in on site guide that if there's no rcd protection it does require metal earthed capping
below..
[ElectriciansForums.net] capping
That should be big enough ?
As and when we need to substantially widen the chase , we use a Hilti grinder with an extract head on it .
Was just guessing maybe bit narrower, won't take standard capping I know that. I was getting a load of slightly narrower capping for a while which was perfect but can't get no more. smallest stuff 16mm? no use.
- - - Updated - - -
I put a post on about angle grinder extraction the other day...is hilti version good like ?
- - - Updated - - -
As good as you would expect it to be , being Hilti !
Keep meaning to buy another grinder , as they sent two extract heads out with the grinder when we brought a hover and grinder combo kit .
Tried to give the spare head back , but the rep would have none of it !?
- - - Updated - - -
Ive just ordered a new makita grinder but Im thinking I should get the hilti. Could you maybe point me in the direction of the extractor unit ? I see a few on the site but not sure which Id need ?
I have been on their site , but can not tell which one it is at the moment .
I know it is on one of their 5" grinders , but as I tend not to get on the tools nowadays , and especially not for chasseing work , I am not quite sure which one it is !?
I do know from when I was more hands on , it was the daddy ! Especially when it came to cutting a perfect box hole .
I am going down to work early this week so should be back on Wednesday night this week , I will have a look for it at the yard and if I remember when I get back home post the model number up for you .
I do know from when I was more hands on , it was the daddy especially when it came to cutting a perfect box hole .
Excellent thanks..more so the extractor I'm interested in mate...Ill just pick up their basic 5" grinder to accompany it.
Reply to capping in the UK Electrical Forum area at ElectriciansForums.net
Capping off redundant pipework question. Hi all. I done some work for someone a few years ago and I've been getting paranoid that things haven't...
sammy67
If in doubt, hit it with a hammer and see if it gets better. sometimes the simple solutions are the best ones!!
