cannondale0815
The title may not make a whole lot of sense to someone who understands more about car electrics than me, but I hope it makes a bit more sense once you read the following.
It appears that my aftermarket Android radio in my 2014 VW Beetle is causing a parasitic draw on my car's battery, even when the car is parked and ignition is off. This caused my old battery (which has now been replaced, as it wasn't in good health anymore anyway) to completely drain when the car was parked for two weeks.
I identified the fuse in the engine compartment fuse box that is responsible for the radio (when I pull it, the radio does not turn on anymore). The circuit this fuse is on appears to be always on, not ignition switched. Is there a way for me to somehow bridge this fuse with a different one in the same fuse box that is ignition switched, and therefore make the radio fuse be ignition switched as well?
I believe a relay may do the trick (have an ignition switched fuse be the trigger to engage the relay), but is there maybe a simpler way of connecting one fuse slot to another by means of some inline fuse wiring?
-J
-J
- TL;DR
- Can a fuse slot be changed from always on to ignition switched?
