There's a lot of very good quality inverters on ebay (pure sinewave) which are put on by caravan shops as they are returned faulty, you can pick a 1500w one up for £30 and repair it yourself....otherwise new they are about £600 off the shelf( standard non sinewave that used a ramped square wave are about £120 - £150 for the same output) a non pure sinewave inverter will paste Laptop chargers and mobile phone chargers, so are only really suitable for Radios and small TV's...of low financial value...
if ventilation is good where they will go, or you can make/weld up some kind of bracket underneath for them, then I would say 2 Car Batteries with an Auto selector ....if you can be bothered then 1 large 12 Volt Truck Battery sat on the ground underneath and connected in, then packed up and moved would be a better option as they have more energy storage availability and power behind them...
New Truck battery will be about £160(if you buy the very best then about £600, but you are not running a lorry so I wouldn't bother)or you could try using a reconditioned one from a good scrappy- about £30, you can buy a bottle of electrolyte and a bottle of battery water for about £20 and pop in a few Granville Battery ...hang on I will go and look..... Granville "Bat Aid" Tablets...these look like small sterodents and come in a similar tube....these aid the Battery performance by keeping the Lead plates inside clean and free from Lead Sulphate...they are about £5.00 for a tube....using a Battery Lug fuse is a good idea as well....
type out a wall chart showing what combinations of things can be plugged in and how long each combination will take to drain the battery when off charge.....otherwise somebody will plug in 2 TV's a Toaster and a Hairdryer at the same time and paste the Battery...
I would fit 2 single sockets , one at each end of the caravan only wired to the inverter, label them as "Mains from Battery Inverter"
being able to charge the battery with a standard Battery charger from the mains on a changeover that swaps out the solar panel(s) would be handy for when heading off from site to site where mains might not be available later on.....
