Caravan TT system hook up point. | on ElectriciansForums
Discuss Caravan TT system hook up point. in the Australia area at ElectriciansForums.net
dogwind
Hi i was wondering what the downside to connecting the earth to an earth rod TT system AND to the TNCS from which the supply is being fed from, i understand that in the fault of the pme neutral going down that a caravan could become live under fault conditions but surley 2 earth paths would be safer than the TT alone which as we all know is dependant on how moist and conductive ground is around the earth rod. Can anyone tell me what the dangers are of connecting to both earth systems.
Thanks for your reply truckster, I did see in the regs it isnt allowed to be a PME so i wasnt going to connect it anyway but just wanted to know the dangers of connecting to both TT and PME, I didnt think of it using the TT caravan hookup point and caravan as the PME earth path but now it all makes sense.
Cheers for the advice
Reply to Caravan TT system hook up point. in the Australia area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
