Carbon Brushes | on ElectriciansForums
Discuss Carbon Brushes in the Electrical Tools and Products area at ElectriciansForums.net
A
Adam W
Anyone know where I can get a set of carbon brushes for an SDS drill, for a reasonable price?
ÂŁ9.70 seems a little steep for what's essentially a bit of coal on a spring.
It's a cheapo Challenge one (not mine) which is probably only worth about ÂŁ50, hence not wanting to spend a lot on it.
Reply to Carbon Brushes in the Electrical Tools and Products area at ElectriciansForums.net
Firstly if you're dismantling it to replace one bearing then just do both bearings, it's not woth trying to save a few bucks and having to do the...
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
