Cat 2 600x600 suspended ceiling lights | on ElectriciansForums
Discuss Cat 2 600x600 suspended ceiling lights in the Australia area at ElectriciansForums.net
Swansea, South Wales
Hi Peeps
I am trying to find some CAT 2 suspended ceiling fittings 600x600.Im replacing some in an office. The problem is the depth from the suspended ceiling to the original ceiling is only 17cm. All the wholesalers iv been to only sell the ones which you put up at an angle then they rest on the bars. Well because the ceiling gap is so small i cant get them in at the angle. Does anyone know where i can get the ones which go up square and wings come out to hold them in place? Anyone know of any websites i can get them from or whats the correct name for them?
what i have done in similar situations is to remove one of the 600 grid bars and get them in that way, or find a place where there is more clearance and shuffle them along on top of the false ceiling. hope this helps.
most modulars are about 100mm deep or there abouts, so with 170mm you should have plenty of room, even if you have to move a tee or two. tip: remove one tee and put all the lights up there, saves the risk of more damage than nececery.
alternatively thorn do a fitting that can be pushed up from below the grid and then you push out some retaining clips out of the sides.
Reply to Cat 2 600x600 suspended ceiling lights in the Australia area at ElectriciansForums.net
