Cat 5/5e/6 installation and termination
CAT 6 must be installed correctly for you to optimise its performance sweeping bends only and definaltley no 45 bends or kinks, Cat5 is alot more robust when it comes to passing test results and can be ragged around alot more. Rember max distance of 100mtrs this distance also includes patch leads so generally 94-95 mtrs point to point.
If your going further than 100mtrs then a secondary cabinet may be required with a link between the 2 cabs.
I spent 10 yrs doing data comms before I turned to electric so any questions fire away
when i mentioned aboput duplicating points, ie looping from one to the next, (only 1 to be used at a time), is this common practice? ive been told to do it before, in a training room so that the instructor can choose where to plug into.
does anybody know what i can buy to test the cable/terminations etc. i've recently installed a cat 6 system but they havent organised the broadband connection yet (4months later). i'd like to know that it all works and they just have to 'plug in'
thanks
got my tester off ebay £8.99. just plug in at each end. fairy lights show each pair OK ( not the tester to use on MOD IT, but does for domestics.)
Hi All If you are only doing a domestic or small office and no comms cabinets are about then i have seen many wee networks where the router switch end of the cat5 cable radial runs are just a few double data points nice and easy to install .I have done a few this way myself using basic tools and a basic tester and i am by no network engineer .
cheers 72-van
Hi Sythai Thats almost exactly what i have ok for once in a blue moon type wee domestic jobs but as the experienced boys say not much cop if u were using it often and useless to diagnose tricky faults.Ok if your on a strict budget and only doing domestic stuff.I store mine in a wee plastic box with clip on lids type of thing you use to put leftover foodinto the freezer in .I also carry a spare 9v battery in the same wee box handy for this lan tester and my continuity tester.
cheers 72-van
Hi there,
Have completed many office refurbs and put anything up to 14 points per office back to comms cupboard and connected to patch panels.I check and test with a simple Ideal tester basically just tests end to end termination.Then have a Lancat datacom 6 unit which will certify up to 250mhz speed.All installs now CAT 6,spend the right money on cable about £70 to £85 per 305metres box.Wilts do there own brand which is very good or try Cable Monkey or BLack Box.Only time i have ever had problems is with cheap wholesale Cat 5e stuff,stay well clear.Only use MK logic brand Cat6 connectors although just got some from Mintrans to play with.You must keep the stripping of the cable to a minimum as this does have some effect of performance (so they say). The picture above looks very neat but outer insulation stripped back to far.And a previous post mentioned about other trades showing no regards for you nice cable runs,very true.The Wilts stuff is purple and very obvious ,yet everyone seems to tread on it and use the same feed holes through buildings.
A lot of installs are redone in compartment trunking so power and data are seperated,but if power runs to close to data you do get some effect of performance so plan your runs.No kinks and plenty of sweeping bends and don't cable tie everything to tight.You can get some good velcro straps now.
Cheers,
cheers 72-van
:) Have put my order in, if it's no good and need to find any faults then time to call a professional :)
I have 10 years experience with data cabling. Data is basically point to point....
each computer has its own data point..... no rings or radials
your switch connecta all of your data points via the patch panel and your server connects into the switch.
If i can be of any assistance let me know.... FYI the diff between cat5e and cat6 is double the bandwidth...... can do more down one cable
doesnt like being bent though cat6!
ok thanks mate, does that eliminate the need for a data cabinet? and whats the diff between cat 5 and cat 6 cables? so its as simple as that? running radials and terminating them at each box and at the source?
errmm think its one ;)
sparx1983,
ColinACJL,
