CAT 5 cable and connections tester suggestions... | on ElectriciansForums
Discuss CAT 5 cable and connections tester suggestions... in the Electrical Tools and Products area at ElectriciansForums.net
O
Octopus
So I borrowed one of these recently when I was connecting up my hard wired CAT 5 connections in our place:
[ElectriciansForums.net] CAT 5 cable and connections tester suggestions...
Which worked OK, but I found I had to look at both "devices" when checking each connection... so I'm interested in buying one, but preferably one which you can connect at both ends of the connection and only look at 1 device.
Hope this makes sense
i do a fair bit of temporary network install for events etc, so it's great for that as the remote is just that, no indicators on it, all the indication is on the handheld, of course you do have to walk back to collect the remote when finished.
Hi anyone have experience of using the Netscout G2 tester and Fluke CIQ100 verification tools, ideally looking for tools that are more cost effective any ideas, need to validate for end user client that cables are fit for purpose. Thanks in advance.
what i got into the habit of doing was to power up the camera indoors, by the recorder ( VHS of course) and monitor, focus it all down there in comfort, then fix it up and just a tweak when up ladder or roped to a pub chimney.
Reply to CAT 5 cable and connections tester suggestions... in the Electrical Tools and Products area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
Which begs the question, where does the second brown wire come from?
