cat points | on ElectriciansForums
Discuss cat points in the UK Electrical Forum area at ElectriciansForums.net
Exeter
Hi guys,
Don't know too much about network cabling.
I need to run to a area where there is two computers being used and so need a 2 gang cat point.
Can I just daisy chain, or is it wise to send individual cables back to the hub?
Absolute maximum is 100m. (to stay within the standards) Work on 90 m. for the installed (solid core) cable from patch panel to outlet, and leaving up to 10 m. for the patch leads (flexible cable) at each end.
If you've got the job of terminating cables (and you've not done it before) take a look a some of the previous threads here's a starter for 10 :) :- http://www.electriciansforums.co.uk.../86346-data-comms-questions-2.html#post893636
if you are going to get close to the limit then an ethernet extender would be a good idea
this is the first one that came up in google (ir explains it)
instead of needing a power source it uses poe to power the device to boost the signal
www.veracityglobal.com/products/ethernet-and-poe-devices/outreach-max.aspx
you will need 1 cable per point, a punchdown tool is a must as well, makesure to use at least cat5e, cat6 etc
Reply to cat points in the UK Electrical Forum area at ElectriciansForums.net
Issue is certain sizes of cable may theoretically be okay but upon the proper testing when it’s commissioned things like a thing may not test out...
Not totally clear what cables are accesible in the loft, but ... Can you not just feed a permanent L & N from the switch to each of lights 2 and...
