catenary wire heights on bungalows | on ElectriciansForums
Discuss catenary wire heights on bungalows in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Putting together plans for a job in few weeks. Will need to run a new catenary
wire over to the garage from bungalow, length approximately 6m.
Was a previous wire in place before the old supply was removed. it is now sagging and not fit for purpose.
Cable will cross over edge of lawn and wont cross above any parking area or be likely to be hit by anything.
Whats the minimum height cables should be suspended? all the references in the various books give a minimum height of 3.5m I can not achieve due to it being a small bungalow, cable exit poitn from house and fuseboard is a small pantry type room, highest point I can reach here is 2.65m
Digging and burying an SWA is not possible due to ground conditions and property being used by a care company to look after a disabled resident. most of garden is concrete or paved and very smooth and flat. told it cant come up due to wheelchair use etc..
Do I just record it as a departure on the certificate?
Gavin in the USA it is 3.5 meters minimum
If you can't achieve 3.5m then I'd say you go as high as you can, what are the risks at 2.65m?
Also what will the height be in the middle with cable sag? Will this pose a risk?
417.3 basically says refer to ESQCR 2002 schedule 2 but that seems to refer more to overhead distribution for HV supplies.
Thats where I was a bit bemused too, it doesnt really cover a domestic setting across a back garden.
In terms if sag I will only be putting 3 core 2.5mm H07 on the wire. Not too heavy. Have done longer runs before with H07.
Did have a liitle booklet that allowed you to calculate the sag and stretch in the wire when suspended depending on the the type of cable.wish i kept it now.
Get one of those rubber strips that you run across an office floor to contain cables.
And if its for a wheelchair user.... it doubles as a speedbump.
:eek:Noooo..... you can't say that!!!!!
Little spark that comment was very disrespectful, my brother had a leg amputation and in a wheelchair. Never make fun of the less fortunate
You have to get used to our dry British humour mate. I don't think that @littlespark meant any disrespect by it... My northern mate takes the micky out of me and I'm less fortunate.... He's waaaay better looking than me...
Reply to catenary wire heights on bungalows in the UK Electrical Forum area at ElectriciansForums.net
