catenary wire heights on bungalows | Page 2 | on ElectriciansForums
Discuss catenary wire heights on bungalows in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Putting together plans for a job in few weeks. Will need to run a new catenary
wire over to the garage from bungalow, length approximately 6m.
Was a previous wire in place before the old supply was removed. it is now sagging and not fit for purpose.
Cable will cross over edge of lawn and wont cross above any parking area or be likely to be hit by anything.
Whats the minimum height cables should be suspended? all the references in the various books give a minimum height of 3.5m I can not achieve due to it being a small bungalow, cable exit poitn from house and fuseboard is a small pantry type room, highest point I can reach here is 2.65m
Digging and burying an SWA is not possible due to ground conditions and property being used by a care company to look after a disabled resident. most of garden is concrete or paved and very smooth and flat. told it cant come up due to wheelchair use etc..
Do I just record it as a departure on the certificate?
Megawatt where are you from
Matthew I’m from North Carolina in the USA and I joined this forum to learn how other countries do electrical and I’m impressed at how you guys investigate matters of electrical. I’ve had 14 heart attacks and l look forward to chatting with y’all since I can’t work a full time job
You have to get used to our dry British humour mate. I don't think that @littlespark meant any disrespect by it... My northern mate takes the micky out of me and I'm less fortunate.... He's waaaay better looking than me...
[ElectriciansForums.net] catenary wire heights on bungalows
well spoon see if the yank doodle get this one ,lol.:D
I am also interested to in other countries methods. I have a book on French wiring (in English for expats). I like their idea of switch wires being identified by being orange or violet, both being used on two way switching circuits for the strappers. Of course this can only really be done using singles in conduit.
Last year on a trip to New York bought a book called Wiring Simplified in Home Depot. Looking through it I was surprised to see that when sockets (receptacles) are wired in line the favoured method was to pigtail wires together using wire nuts in the back box, only taking one set of wires to the receptacle. Further reading I found out about three wire circuits, basically two 120v 180Ëšphases carried on three wires often to different single phase receptacles in the same room and the importance of retaining the integrity of the neutral if sockets are removed. Surprised that sometimes that two outlets on a single receptacle can also be on different phases after cutting the links between the two. I have seen 6 way blocks with a twin plug on the back designed to go into a double outlet. Do these have three on each plug otherwise I can sparks flying if they are just paralleled? Also surprised that receptacles are mandatory in bathrooms, all be it GFI protected, something that would horrify sparks over here. I don't like the US 2 pin polarised plug with just two extra pips on the side of the neutral pin, too easy to default with say a nail file. Much better if the entire pin was wider.
i got up this morning and had to look at that picture lm speechless
BS7671 dont buy it. Just download the draft copy thats floating around internet. The book is about ÂŁ60+
It's not very exciting reading also
We have tamper proof receptacles so
No they don’t make 3 ways and with the filing thE NEC now requires tamper proof receptacles so nail filing would just ruin them
the GFCI is required for bathrooms because women have to use their hair dryers and they also have to be within 3 feet on both sides of your kitchen sinks. Why would that make you horrified
Don't followthat. Surely a filed down polarised plug is the same as a non polarised plug, and there are still plenty of those about, iphone chargers come to mind. Are you saying tamper proof receptacles would not accept them?
Reply to catenary wire heights on bungalows in the UK Electrical Forum area at ElectriciansForums.net
