catenary? | on ElectriciansForums
Discuss catenary? in the Australia area at ElectriciansForums.net
L
lionelmcc
What kind of cable would you chaps recommend for power to a shed?
I haven't looked at the job yet and will use SWA if I can find a route.
If I have to go overhead what type of cable can I use withe centenary?
Any other options?
L
Hey Li.
You can use a T+E on a catenery wire, suitably sized for whatever will be in the shed. Usually a minimum of 6mm T+E is sufficient on a domestic premesis. SY is possibly another option, depends on the risk of damage really. I have also seen SWA on a catenary before now.
I also bond the catenary wire in 4mm earth and a line tap.
Cheers.
Yes.
On a small overhead between a house and garden shed say. I've seen literally hundreds of these particularly on farms, and confess I have used a T+E overhead on the odd occasion myself only on a span of about 2-3m.
Depending on the op's situation a trenched armoured is a far better job.
Reply to catenary? in the Australia area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
Are you meaning running two 6mm cables in parallel? This is allowable in UK regs, providing the two runs are exactly the same length and routing...
