CCTV cable drop | on ElectriciansForums
Discuss CCTV cable drop in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Flash
Aylesford
Can any one point me in the right direction, I've been asked to quote for power supply only for 5-6 cctv cameras the distance of the cable is 1500 metres and have been told a maximum of 30 amps, doing cable drop calculations I'm coming out at over 95mm swa??? I must be doing something wrong? my heads hurting!!
I think the solution might be to run a 230v ring, then a small local psu at each camera location?
Current will then be so low, volt drop will be negligible
just cameras, apparently they are roughly 5 amps per camera, but i have since found out that each column will have a poe that converts to 24v ac
Reply to CCTV cable drop in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
We used to have one in our hallway, had a metal backstop with some spinners set up in it! Great with the air rifle! I left holes in the Plaster...
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
