ceiling fan/light | Page 2 | on ElectriciansForums
Discuss ceiling fan/light in the Australia area at ElectriciansForums.net
still learning.
hi, I have just put right the wiring to a ceiling fan/light for my mate and it works exept when the fan is turned on it makes a noise until the light is turned on and then it is quiet, could this be cos of the wiring or just because it was a cheap fan.
it had a connector block in it labled L,N,Light, i put the switch live to L, neutral to N, and a wire from the L to the Light is this correct?
thankls
no just the one pull switch, there is a tiny slide switch for the fan which you need a chair the reach it was only a very cheap fan.
thanks
As Andtfm says, you can wire it both ways but you do not want to be running the fan motor through the dimmer.
As for the noise, it could be in the small print.
Reply to ceiling fan/light in the Australia area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
