Ceiling Light Wiring | Page 2 | on ElectriciansForums
Discuss Ceiling Light Wiring in the UK Electrical Forum area at ElectriciansForums.net
Britain
Hi Guys, Was wondering if you could help me out regarding identifying the neutral and live for this ceiling light. I am going to cut the transparent flex so it will hang to the length I want but there is no 'red' or 'blue' colouring on the inner conductors. Would appreciate any advice on how to identify which one is which
[ElectriciansForums.net] Ceiling Light Wiring
. thanks! :)
I have a voltage detector. how do you test it? thanks
Of course the threads will be live on the lamp as they are one of the connections. Modern ES lampholders shroud the threads better but they are still live and the should be wired with the correct polarity, L to tip, N to threads.
its nice to see novices have a go doing electrical things over the xmas period could end In a big mistake .flak jacket on !!!!!
Just to clarify, ES lamp holders manufactured prior to 2004 may well be polarity biased so the centre contact must be connected to the line conductor. Lamp holders manufactured in compliance with BS EN 60238 2004 are not polarity biased as both contacts are at the base of the lamp holder and the outer metal screw contact of the lamp will not be exposed as a live part due to construction of the lamp holder.
its nice to see novices have a go doing electrical things over the xmas period could end In a big mistake .flak jacket on .
don't worry I'll try not to,
haha aren't you hilarious, good to know we have experts like you out there!!
haha, aren't you hilarious!
That may be so, but it is still good practice to wire it correctly with the live to the tip. As I said:
"Modern ES lampholders shroud the threads better but they are still live and the should be wired with the correct polarity, L to tip, N to threads."
Good practice to wire it correctly with the live at the tip, nonsense it makes no difference how it is connected. By time the thread reaches the contact in the base off the lamp holder it is shrouded.
Having just googled the subject and inspected some modern ES lampholders in my house, would appear that westward is correct. And Reg 612.6 gives exception E14 & E27 lampholders to BS EN60238.
My E27 lampholder thread is plastic, whilst the lamp's thread is still metal, and if connected to 'live', will be live in service. However, due to the construction of the lampholder, the threads cannot be touched with a finger during service. If the lamp is faulty & but still in contact with 'live' and the lamp unscrewed, contacts are disconnected before a finger can make contact with the lamps metal thread. My E14 is lamp is also so designed.
However, you are correct that good practise should continue, but it appears it is not a requirement, hence perhaps why this manufacture does not see it as an issue, and the leads are not identified?
It isn’t dangerous to have too much knowledge, the danger comes from estimating how much you actually have.
Clue - you need to test whether the Earth path is viable to keep you safe in the event of a fault. That needs testing, although I suspect that knowledge will ironically be too much.
how can too much Knowledge be dangerous? if I don't feel confident doing it I won't. just need to know how to identify between which is the live and which is the neutral.
Its a light fitting, there have probably been thousands bought & put up by people across the country this weekend. Now whilst some people are clueless with these things, a lot of people aren't. It we be great for us electricians, if people were banned from doing such things, more money for us.
OP has asked a sensible question, and given suitable guidance. Unless he starts showing us pictures of a ceiling rose, and how do I do that etc, lets not turn into one of 'those' threads. IMO
Reply to Ceiling Light Wiring in the UK Electrical Forum area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Least it looks like your at the end of line of loop in method cos you could may have had an extra live ,neutral earth.fun terminating into what...
