Ceiling lighting advice for novice | on ElectriciansForums
Discuss Ceiling lighting advice for novice in the UK Electrical Forum area at ElectriciansForums.net
Kiddermister
Hi all,
Found myself here as I am looking for some advice on ceiling lights and it seemed like a friendly place!!
I have a very dark kitchen with only 1 ceiling light. I really don't like the commercial spot light fixtures and would like to replace the single light with a few recessed down-lights. As the floor above is not really accessible, I intend to build a partial false ceiling from MDF, paint and attach to the existing ceiling. I figured this would be easier that chasing out the ceiling or trying to drill through joists from the underside. My question therefore is this, can I just wire up 6 recessed down-lights from this 1 set of wires for the existing light? and if so, how do I go about doing this? I guess I need to ask if I am actually allowed to do this also? The idea would be do have all the wiring/connectors in the hollow I would be creating in the false ceiling. I could make this accessible or not, depending on regulations. (for example, I could screw the false ceiling into place, paint but use caps so it's removable if need be.)
Many thanks and look forward to reading any replies. Would be a great help.
Just out of interest, have you thought about track lighting? A strip running the length of the kitchen fed from the existing lighting position with multiple LED spotlights lighting the kitchen.
I had thought about it, but again, I think they are just spots?? no? I would like something that gives off a more ambient light I guess. I thought that recessed ceiling lights (larger ones) would do this, if I could.
4x2 timber all round and at 16ins centres half ins plasterboard on that .cables in beforehand ,job done
Yeah, I can do the woodwork and plasterboards stuff, it's the wiring I have no clue about. How do I wire from 1 existing fitting to 6 or 8 down-lights? Sorry, It's probably very obvious but I have no clue. As in I have 3 wires, yet potentially 6 lights to wire from it? Do I just use a junction box and daisy chain em from there?
Use plasterboard as it has more fire retardant properties than MDF.
'Daisy Chain' is wiring from one light to another, then another. Not all from one junction box.
If you have not done any electrical work before how are you going to test the circuit?
How confident are you with wiring up lights?
You could get a track light with light that have a more angled light than 'just spots'.
I guessing you mean 3 sets of twin and earth cables? Meaning 1x perm feed in, neutral and earth 1x perm. Feed out, neutral and earth. 1x perm. Feed to switch (normally red/brown) , switch line from switch to fitting (normally black/blue) and earth. You want to keep the 2x perm feed together along with the feed to switch. Both the neutrals plus a new neutral from a new run of twin and earth. Connect the switch line from switch with live of new twin and earth and then daisy chain.
Edit: obviously connect all the earths together.
Wow. I have no idea what you said, sorry mr2 gd4u!!
Can I just wire up the existing 3 wires into a junction box, then come out of it to 6 separate lights? I guess I just figured as the wiring is there, its just a case of extending it and coming off it?
If I can't do this myself, then what kind of cost to do any wiring? Thank you!!!!
By that answer I would say get someone in. I'd say min. ÂŁ250 depending on area
Reply to Ceiling lighting advice for novice in the UK Electrical Forum area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
ok cheers for the help lads
