Advice needed,
Removed a ceiling rose and the cables must have been loose as they all popped out. Connected up all the cables apart from the grey cable. My PIR light outside is now not working without this grey cable connected into one of the blocks which is fed off the same switch bank on the wall. I believe the grey cable should go into the live brown block. Any help appreciated.
